Connected Tropical Subgraphs in Vertex-Colored Graphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2016
A subgraph of a vertex-colored graph is said to be tropical whenever it contains each color of the graph. In this work we study the problem of finding a minimal connected tropical subgraph. We first show that this problem is NP-Hard for trees, interval graphs and split graphs, but polynomial when the number of colors is logarithmic in terms of the order of the graph (i.e. FPT). We then provide upper bounds for the order of the minimal connected tropical subgraph under various conditions. We finally study the problem of finding a connected tropical subgraph in a randomly vertex-colored random graph.
2765-9988-2-PB.pdf (310.1 Ko) Télécharger le fichier
Origine : Accord explicite pour ce dépôt
hal-01352845 , version 1 (17-08-2016)
Jean-Alexandre Anglès d'Auriac, Nathann Cohen, Hakim El Mafthoui, Ararat Harutyunyan, Sylvain Legay, et al.. Connected Tropical Subgraphs in Vertex-Colored Graphs. Discrete Mathematics and Theoretical Computer Science, 2016, Vol. 17 no. 3 (3), pp.327-348. ⟨10.46298/dmtcs.2151⟩. ⟨hal-01352845⟩
314 Consultations
1257 Téléchargements
