A simple pressure stabilization method for the Stokes equation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal for Numerical Methods in Biomedical Engineering Année : 2008
In this paper, we consider a stabilization method for the Stokes problem, using equal-order interpolation of the pressure and velocity, which avoids the use of the mesh size parameter in the stabilization term. We show that our approach is stable for equal-order interpolation in the case of piecewise linear and piecewise quadratic polynomials on triangles. In the case of linear polynomials, we retrieve a well-known idea of using mass lumping as a stabilization mechanism.
BHB.pdf (484.08 Ko) Télécharger le fichier
hal-01352889 , version 1 (10-08-2016)
Paternité
Roland Becker, Peter Hansbo. A simple pressure stabilization method for the Stokes equation. International Journal for Numerical Methods in Biomedical Engineering, 2008, 24 (11), pp.1421-1430. ⟨10.1002/cnm.1041⟩. ⟨hal-01352889⟩
Collections
CNRS UNIV-PAU
144 Consultations
922 Téléchargements
