Using Attribute-Oriented Programming to Leverage Fractal-Based Developments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
This paper presents the Fraclet annotation framework. The goal of Fraclet is to leverage Component-Based Software Engineering based on the Fractal component model using Attribute-Oriented Programming. We show that, using Fraclet, about 50% of the handwritten program code can be saved without loosing the semantics of the application, while the rest of the program code is automatically generated.
0607-ecoop.pdf (290.78 Ko) Télécharger le fichier
hal-01353552 , version 1 (11-08-2016)
  • HAL Id : hal-01353552 , version 1
Romain Rouvoy, Nicolas Pessemier, Renaud Pawlak, Philippe Merle. Using Attribute-Oriented Programming to Leverage Fractal-Based Developments. 5th International ECOOP Workshop on Fractal Component Model (Fractal’06), Jul 2006, Nantes, France. ⟨hal-01353552⟩
242 Consultations
179 Téléchargements
