New interface
Reports (Research report)
A High Order Method for Contour Integrals with an Application to Plasma Modeling in Nuclear Fusion
Abstract : We introduce a novel method to compute approximations of contour integrals. The new method is based on the coarea formula in combination with a Galerkin projection. As such it fits seamlessly into the spirit of hp/spectral finite element methods and circumvents the expensive and technical computation of contours. We provide convergence estimates showing that high order convergence can be achieved provided the data is sufficiently smooth. The theoretical results are supplemented by extensive numerical experiments for an example application from plasma modeling in nuclear fusion.
Document type :
Complete list of metadata
Cited literature [32 references]  Display  Hide  Download
https://hal.inria.fr/hal-01354031
Contributor : Holger Heumann Connect in order to contact the contributor
Submitted on : Wednesday, August 17, 2016 - 2:31:51 PM
Last modification on : Wednesday, October 26, 2022 - 8:15:46 AM
Long-term archiving on: : Friday, November 18, 2016 - 10:02:19 AM
File
RR-8948.pdf
Identifiers
  • HAL Id : hal-01354031, version 1
Citation
Holger Heumann, Lukas Drescher, Kersten Schmidt. A High Order Method for Contour Integrals with an Application to Plasma Modeling in Nuclear Fusion. [Research Report] RR-8948, INRIA Sophia Antipolis - Méditerranée; CASTOR. 2016. ⟨hal-01354031⟩
Share
Metrics
Record views
245
Files downloads
269
