Guest Editorial Special Issue on Medical Imaging and Image Computing in Computational Physiology - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Medical Imaging Année : 2013
The January 2013 Special Issue of IEEE transactions on medical imaging discusses papers on medical imaging and image computing in computational physiology. Aslanid and co-researchers present an experimental technique based on stained micro computed tomography (CT) images to construct very detailed atrial models of the canine heart. The paper by Sebastian proposes a model of the cardiac conduction system (CCS) based on structural information derived from stained calf tissue. Ho, Mithraratne and Hunter present a numerical simulation of detailed cerebral venous flow. The third category of papers deals with computational methods for simulating medical imagery and incorporate knowledge of imaging physics and physiology/biophysics. The work by Morales showed how the combination of device modeling and virtual deployment, in addition to patient-specific image-based anatomical modeling, can help to carry out patient-specific treatment plans and assess alternative therapeutic strategies.
IEEE_TMI_MIinCP_v7.pdf (178.87 Ko) Télécharger le fichier
hal-01355239 , version 1 (22-08-2016)
Alejandro F. Frangi, D. Rod Hose, Peter J. Hunter, Nicholas Ayache, Dana Brooks. Guest Editorial Special Issue on Medical Imaging and Image Computing in Computational Physiology. IEEE Transactions on Medical Imaging, 2013, 32 (1), pp.1-7. ⟨10.1109/TMI.2012.2234320⟩. ⟨hal-01355239⟩
271 Consultations
265 Téléchargements
