Particle Filter-based Direct Visual Servoing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
With respect to classical visual servoing (VS) technics based on geometrical features, the main drawback of direct visual servoing is its limited convergence area. In this paper we propose a new direct visual servoing control law that relies on a particle filter to achieve non-local and non-linear optimization in order to increase this convergence area. Thanks to multi-view geometry and image transfer techniques, a set of particles (which correspond to potential camera velocities) are drawn and evaluated in order to evaluate the best camera trajectory. This new control law is validated on a 6 DOF positioning task performed on a real gantry robot and statistical comparisons are also provided from simulation results.
2016_iros_bateux.pdf (1.62 Mo) Télécharger le fichier
hal-01355396 , version 1 (23-08-2016)
  • HAL Id : hal-01355396 , version 1
Quentin Bateux, Eric Marchand. Particle Filter-based Direct Visual Servoing. IEEE/RSJ Int. Conf. on Intelligent Robots and Systems, IROS'16, Oct 2016, Daejeon, South Korea. pp.4180-4186. ⟨hal-01355396⟩
268 Consultations
301 Téléchargements
