Secured Systems in Clouds with Model-Driven Orchestration - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
As its complexity grows, securing a system is harder than it looks. Even with efficient security mechanisms, their configuration remains a complex task. Indeed, the current practice is the hand-made configuration of these mechanisms to protect systems about which we generally lack information. Cloud computing brings its share of new security concerns but it may also be considered as leverage to overcome these issues. In this paper, we discuss the key challenge of achieving global security of Cloud systems and advocate for a new approach: Model-Driven Orchestration. We present an implementation of this new approach called Security-Aware Models for Clouds and illustrate it on an industrial use-case.
Fichier non déposé
hal-01355681 , version 1 (24-08-2016)
  • HAL Id : hal-01355681 , version 1
Eddy Caron, Arnaud Lefray, Jonathan Rouzaud-Cornabas. Secured Systems in Clouds with Model-Driven Orchestration. The 2nd IEEE Workshop on Security and Privacy in the Cloud (SPC 2016). In conjunction with the IEEE CNS conference. , IEEE, Oct 2016, Philadelphia, United States. ⟨hal-01355681⟩
201 Consultations
0 Téléchargements
