Uncertainty and sensitivity analysis of functional risk curves based on Gaussian processes
Abstract : A functional risk curve gives the probability of an undesirable event as a function of the value of a critical parameter of a considered physical system. In several applicative situations, this curve is built using phenomenological numerical models which simulate complex physical phenomena. To avoid cpu-time expensive numerical models, we propose to use Gaussian process regression to build functional risk curves. An algorithm is given to provide confidence bounds due to this approximation. Two methods of global sensitivity analysis of the models' random input parameters on the functional risk curve are also studied. In particular, the PLI sensitivity indices allow to understand the effect of misjudgment on the input parameters' probability density functions.
Document type :
Preprints, Working Papers, ...
Complete list of metadatas
https://hal.inria.fr/hal-01357005
Contributor : Bertrand Iooss <>
Submitted on : Tuesday, July 25, 2017 - 11:58:32 AM
Last modification on : Thursday, March 5, 2020 - 5:56:24 PM
RESS17_FRC_v2.pdf
Identifiers
  • HAL Id : hal-01357005, version 3
  • ARXIV : 1704.00624
Citation
Bertrand Iooss, Loïc Le Gratiet. Uncertainty and sensitivity analysis of functional risk curves based on Gaussian processes. 2016. ⟨hal-01357005v3⟩
Share
Metrics
Record views
324
Files downloads
1125
