New interface
Reports (Research report)
Finite element method for a space-fractional anti-diffusive equation
Afaf Bouharguane 1, 2
2 MEMPHIS - Modeling Enablers for Multi-PHysics and InteractionS
IMB - Institut de Mathématiques de Bordeaux, Inria Bordeaux - Sud-Ouest
Abstract : The numerical solution of a nonlinear and space-fractional anti-diffusive equation used to model dune morphodynamics is considered. Spatial discretization is effected using a finite element method whereas the Crank-Nicolson scheme is used for temporal discretization. The fully discrete scheme is analyzed to determine stability condition and also to obtain error estimates for the approximate solution. Numerical examples are presented to illustrate convergence results.
Document type :
Complete list of metadata
Cited literature [14 references]  Display  Hide  Download
https://hal.inria.fr/hal-01358184
Contributor : Afaf Bouharguane Connect in order to contact the contributor
Submitted on : Wednesday, August 31, 2016 - 11:33:44 AM
Last modification on : Wednesday, October 26, 2022 - 8:14:31 AM
Long-term archiving on: : Friday, December 2, 2016 - 12:11:58 AM
FEM.pdf
Identifiers
  • HAL Id : hal-01358184, version 1
  • ARXIV : 1608.08830
Collections
Citation
Afaf Bouharguane. Finite element method for a space-fractional anti-diffusive equation. [Research Report] Institut de Mathématiques de Bordeaux; INRIA Bordeaux, équipe MEMPHIS. 2016. ⟨hal-01358184⟩
Share
Metrics
Record views
151
Files downloads
133
