Experimental Study on Forced-Air Precooling of Dutch Cucumbers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Experiments about the forced-air precooling of cucumbers were carried out under different operation parameters. The results show that the relation between cooling rate and air velocity can be given by power function. The linear relationship between the initial temperature of cold air and cucumbers and the final temperature of cucumbers is gained. Temperature gradient exists in different radius position in the same cross section. But the temperature gradient is not significant for the beginning and the final during the procooling process.
978-3-642-27278-3_60_Chapter.pdf (4 Ko) Télécharger le fichier
hal-01361034 , version 1 (06-09-2016)
Paternité
Jingying Tan, Shi Li, Qing Wang. Experimental Study on Forced-Air Precooling of Dutch Cucumbers. 5th Computer and Computing Technologies in Agriculture (CCTA), Oct 2011, Beijing, China. pp.587-593, ⟨10.1007/978-3-642-27278-3_60⟩. ⟨hal-01361034⟩
49 Consultations
76 Téléchargements
