Applying Axiomatic Design Theory to the Multi-objective Optimization of Disk Brake - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The multi-objective optimization involves multiple, competing functionality requirements, which is mainly limited to downstream detailed design. Axiomatic design provides the theory to design a complex system top down and deals with multiple functional requirements (FR). It has demonstrated its strength in various types of design tasks. In fact, the objective function is a FR and those variables affecting the objective function are the design parameters (DPs). This paper presents an application of axiomatic design to multi-objective optimization. First, identify the relationship between FRs and DPs in terms of contribution of each DP to each FR by using orthogonal experiment and analysis of variance (ANOVA); then identify important design parameters to a FR and classify design variables into groups based on uncoupled design philosophy; and then establish the function dependence table, and sequentially optimize every objective function. An application in a disk brake design is used to demonstrate the use of the proposed method in dealing with real-world design problems. The results show that the proposed method provides a promising approach to optimize multiple, competing design objectives.
978-3-642-27275-2_7_Chapter.pdf (4 Ko) Télécharger le fichier
hal-01361120 , version 1 (06-09-2016)
Paternité
Zhiqiang Wu, Xianfu Cheng, Junping Yuan. Applying Axiomatic Design Theory to the Multi-objective Optimization of Disk Brake. 5th Computer and Computing Technologies in Agriculture (CCTA), Oct 2011, Beijing, China. pp.62-73, ⟨10.1007/978-3-642-27275-2_7⟩. ⟨hal-01361120⟩
130 Consultations
377 Téléchargements
