Prediction of Dissolved Oxygen Content in Aquaculture of Hyriopsis Cumingii Using Elman Neural Network - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2012
Hyriopsis Cumingii is Chinese major fresh water pearl mussel, widely distributed in the southern provinces of China’s large and medium-sized freshwater lakes. In the management of Hyriopsis Cumingii ponds, dissolved oxygen (DO) is the key point to measure, predict and control. In this study, we analyzes the important factors for predicting dissolved oxygen of Hyriopsis Cumingii ponds, and finally chooses solar radiation(SR), water temperature(WT), wind speed(WS), PH and oxygen(DO) as six input parameters. In this paper, Elman neural networks were used to predict and forecast quantitative characteristics of water. As the dissolved oxygen in the outdoor pond is low controllability and scalability, this paper proposes a predicting model for dissolved oxygen. The true power and advantage of this method lie in its ability to (1) represent both linear and non-linear relationships and (2) learn these relationships directly from the data being modeled. The study focuses on Singapore coastal waters. The Elman NN model is built for quick assessment and forecasting of selected water quality variables at any location in the domain of interest. Experimental results show that: Elman neural network predicting model with good fitting ability, generalization ability, and high prediction accuracy, can better predict the changes of dissolved oxygen.
978-3-642-27275-2_57_Chapter.pdf (4 Ko) Télécharger le fichier
Dates and versions
hal-01361178 , version 1 (06-09-2016)
Attribution
Identifiers
Cite
Shuangyin Liu, Mingxia Yan, Haijiang Tai, Longqin Xu, Daoliang Li. Prediction of Dissolved Oxygen Content in Aquaculture of Hyriopsis Cumingii Using Elman Neural Network. 5th Computer and Computing Technologies in Agriculture (CCTA), Oct 2011, Beijing, China. pp.508-518, ⟨10.1007/978-3-642-27275-2_57⟩. ⟨hal-01361178⟩
216 View
175 Download
Share
