Marking shortest paths on pushdown graphs does not preserve MSO decidability
In this paper we consider pushdown graphs, i.e. infinite graphs that can be described as transition graphs of deterministic real-time pushdown automata. We consider the case where some vertices are designated as being final and we build, in a breadth-first manner, a marking of edges that lead to such vertices (i.e., for every vertex that can reach a final one, we mark all outgoing edges laying on some shortest path to a final vertex). Our main result is that the edge-marked version of a pushdown graph may itself no longer be a pushdown graph, as we prove that the MSO theory of this enriched graph may be undecidable.
Logique en informatique [cs.LO]
