The initial-boundary value problem for general non-local scalar conservation laws in one space dimension - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Nonlinear Analysis: Theory, Methods and Applications Année : 2017
We prove global well-posedness results for weak entropy solutions of bounded variation (BV) of scalar conservation laws with non-local flux on bounded domains, under suitable regularity assumptions on the flux function. In particular, existence is obtained by proving the convergence of an adapted Lax-Friedrichs algorithm. Lipschitz continuos dependence from initial and boundary data is derived applying Kružhkov 's doubling of variable technique.
boundary_general.pdf (340.43 Ko) Télécharger le fichier
hal-01362504 , version 1 (08-09-2016)
  • HAL Id : hal-01362504 , version 1
Cristiana de Filippis, Paola Goatin. The initial-boundary value problem for general non-local scalar conservation laws in one space dimension. Nonlinear Analysis: Theory, Methods and Applications, 2017, 161, pp.131-156. ⟨hal-01362504⟩
533 Consultations
323 Téléchargements
