Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, EpiSciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
Abstract : In this paper, we report on passive alignment with sub-micron precision of two photonic chips on a silicon optical bench. An effective design principle to minimize the tolerance chain is presented and applied to a case study. The chips have been successfully manufactured and individual characterization of the chips revealed that all critical dimensions were within or close to specs. Sub-pixel analysis of images of assembled chips showed that a repeatability of 0.3 μm from a single photonic chip to the silicon optical bench can be achieved. Moreover, it was demonstrated that passive alignment features defined in the waveguiding layers are robust enough to function as mechanical endstops.
https://hal.inria.fr/hal-01363875 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Monday, September 12, 2016 - 10:03:41 AM Last modification on : Saturday, November 18, 2017 - 6:16:02 PM Long-term archiving on: : Tuesday, December 13, 2016 - 12:57:17 PM
J. Van Gurp, Marcel Tichem, U. Staufer. Design, Fabrication and Testing of Assembly Features for Enabling Sub-micron Accurate Passive Alignment of Photonic Chips on a Silicon Optical Bench. 6th International Precision Assembly Seminar (IPAS), Feb 2012, Chamonix, France. pp.17-27, ⟨10.1007/978-3-642-28163-1_3⟩. ⟨hal-01363875⟩
