Abstract : The following approach of a fluidic based self-assembly process uses the surface forces for a precise handling and positioning of small devices for a roll-to-roll manufacturing. The surface, on which the device should be positioned, will be functionalized with hydrophile and hydrophobic areas. Thus water droplets can be caught on the hydrophile areas. The devices to be positioned will be placed on these droplets and due to the surface tension moved to their final position. The droplets, a solution of ultrapure water and isopropanol, are evaporating residue-free within seconds [1].
https://hal.inria.fr/hal-01363877 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Monday, September 12, 2016 - 10:04:08 AM Last modification on : Tuesday, October 19, 2021 - 12:49:45 PM Long-term archiving on: : Tuesday, December 13, 2016 - 12:49:19 PM
Matthias Burgard, Norbert Schläfli, Uwe Mai. Processes for the Self-assembly of Micro Parts. 6th International Precision Assembly Seminar (IPAS), Feb 2012, Chamonix, France. pp.36-41, ⟨10.1007/978-3-642-28163-1_5⟩. ⟨hal-01363877⟩
