Tolerance Management for Assembly – Not a Matter of Product Size - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Today’s industrial assembly systems have to enable individualized production as well as to feature a high degree of automation to cope with both quality requirements and increasing cost pressure. An overall tolerance concept is necessary to allow processes under the above referenced conditions. Reducing costs and the complexity of assembly processes can be achieved by an assembly product design based on the information provided by a tolerance analysis. This paper describes industrial standards and innovative concepts of a holistic tolerance management that are independent of product size.
978-3-642-28163-1_13_Chapter.pdf (4 Ko) Télécharger le fichier
hal-01363889 , version 1 (12-09-2016)
Paternité
Rainer Müller, Martin Esser, Christian Janssen, Matthias Vette, Stefan Quinders. Tolerance Management for Assembly – Not a Matter of Product Size. 6th International Precision Assembly Seminar (IPAS), Feb 2012, Chamonix, France. pp.97-104, ⟨10.1007/978-3-642-28163-1_13⟩. ⟨hal-01363889⟩
164 Consultations
1096 Téléchargements
