Control Interfaces for a Collaborative System Using LabView Package - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Alina Ninett Panfir
  • Fonction : Auteur
  • PersonId : 986675
Alexandra Covaci
  • Fonction : Auteur
  • PersonId : 988828
Cristian-Cezar Postelnicu
  • Fonction : Auteur
  • PersonId : 988829
Gheorghe Mogan
  • Fonction : Auteur
  • PersonId : 988830
In-robotics functions, performed by the software, include data acquisition, motor control, sensor signals processing, perception of objects and navigation through environment. LabView provides a solution to the limited skills and the limited time problem that appears when we use programming environments like C++ or Java. This document introduces the implementation of a communicative mobile robotic system that is based on two collaborative Pioneer robots controlled by user friendly interfaces developed in LabView. The purpose of developing this type of interfaces was to allow a complex collaborative system to adapt to any platform and be used by any type of user, without depending on his robotics knowledge level.
978-3-642-28255-3_4_Chapter.pdf (4 Ko) Télécharger le fichier
hal-01365563 , version 1 (13-09-2016)
Paternité
Alina Ninett Panfir, Alexandra Covaci, Cristian-Cezar Postelnicu, Gheorghe Mogan. Control Interfaces for a Collaborative System Using LabView Package. 3rd Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Feb 2012, Costa de Caparica, Portugal. pp.33-40, ⟨10.1007/978-3-642-28255-3_4⟩. ⟨hal-01365563⟩
69 Consultations
124 Téléchargements
