Asynchronous-Channels and Time-Domains Extending Petri Nets for GALS Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
A specific class of Petri nets was extended with Asynchronous-Channels (ACs) and Time-Domains (TDs) to support Globally-Asynchronous Locally-Synchronous (GALS) systems’ modeling, analysis and implementation. This non-autonomous class of Petri nets is targeted to support the development of automation and embedded systems using a model-based development approach. It benefits from a tool chain framework previously developed, covering the whole development flow, from specification to hardware and software deployment. With the extended Petri net class is possible to model GALS systems, and use the specification to generate the corresponding state space supporting the behavior verification and providing valuable information for implementation.
978-3-642-28255-3_16_Chapter.pdf (4 Ko) Télécharger le fichier
hal-01365579 , version 1 (13-09-2016)
Paternité
Filipe Moutinho, Luís Gomes. Asynchronous-Channels and Time-Domains Extending Petri Nets for GALS Systems. 3rd Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Feb 2012, Costa de Caparica, Portugal. pp.143-150, ⟨10.1007/978-3-642-28255-3_16⟩. ⟨hal-01365579⟩
87 Consultations
94 Téléchargements
