A New Approach to Rational Discrete-Time Approximations to Continuous-Time Fractional-Order Systems - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2012
In this paper a new approach to rational discrete-time approximations to continuous fractional-order systems of the form 1/(sα+p) is proposed. We will show that such fractional-order LTI system can be decomposed into sub-systems. One has the classic behavior and the other is similar to a Finite Impulse Response (FIR) system. The conversion from continuous-time to discrete-time systems will be done using the Laplace transform inversion integral and then applying the Bilinear transformation to obtain the corresponding discrete-time system and the corresponding frequency response. An optimization algorithm will be used to find the FIR type parameters that best approximate the discrete-time system.
978-3-642-28255-3_27_Chapter.pdf (4 Ko) Télécharger le fichier
Dates and versions
hal-01365592 , version 1 (13-09-2016)
Attribution
Identifiers
Cite
Carlos Matos, Manuel Duarte Ortigueira. A New Approach to Rational Discrete-Time Approximations to Continuous-Time Fractional-Order Systems. 3rd Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Feb 2012, Costa de Caparica, Portugal. pp.251-258, ⟨10.1007/978-3-642-28255-3_27⟩. ⟨hal-01365592⟩
68 View
92 Download
Share
