Adaptive Filter and Resonant Controller Applied to Hybrid Series Active Power Filter
This paper proposes a control strategy for Hybrid Active Series Power Filter (HASPF) based on a P+Resonant compensator. The proposed control uses Adaptive Notch Filter to isolate the harmonic content of the source current and a P+Resonant regulator to calculate the harmonic voltage signal necessary to properly tune the hybrid branch. This control strategy ensures multiple frequencies tuning by using only one passive filter. The details of the control algorithm and the design procedure are presented. Experimental results using a single-phase HASPF prototype confirm the effectiveness of the suggested approach.
