Experimental Results of Parallel Active Filter Implementation in Nonideal Power Grid - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper is devoted to the implementation of a parallel active power filter prototype in a nonideal power grid. The control algorithm is described and realized. Simulation and experimental results proved the theoretical prediction. Analytical conditions of the usable implementation are shown. Some guidelines are presented in the conclusion.
978-3-642-28255-3_32_Chapter.pdf (4 Ko) Télécharger le fichier
hal-01365598 , version 1 (13-09-2016)
Paternité
Oleksandr Husev, Andrei Blinov, Dmitri Vinnikov. Experimental Results of Parallel Active Filter Implementation in Nonideal Power Grid. 3rd Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Feb 2012, Costa de Caparica, Portugal. pp.291-298, ⟨10.1007/978-3-642-28255-3_32⟩. ⟨hal-01365598⟩
42 Consultations
72 Téléchargements
