Experimental Analysis of a Standalone Renewable Energy Based Hybrid System - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper presents a small-scale prototype of a wind-photovoltaic hybrid system, having batteries as energy storage components. All devices are connected to a common dc-bus using appropriate power converters. The photovoltaic modules are connected through a dc-dc buck converter using Perturb and Observe Maximum Power Point Tracking control. The permanent magnet synchronous generator (wind generator) power interface is composed of a three-phase diode-bridge rectifier followed by a buck converter. A bidirectional buck-boost converter is applied to the batteries in order to control the dc-bus voltage, to which the load is directly connected. The whole hybrid system was built as a laboratory prototype, by using a dSPACE digital controller. Several experimental results are presented in order to analyze the system performance under both steady state operation and transients.
978-3-642-28255-3_37_Chapter.pdf (4 Ko) Télécharger le fichier
hal-01365603 , version 1 (13-09-2016)
Paternité
Nuno Freire, Eunice Ribeiro, António Marques Cardoso, Chiara Boccaletti. Experimental Analysis of a Standalone Renewable Energy Based Hybrid System. 3rd Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Feb 2012, Costa de Caparica, Portugal. pp.337-344, ⟨10.1007/978-3-642-28255-3_37⟩. ⟨hal-01365603⟩
63 Consultations
240 Téléchargements
