Efficient Hybrid Continuous-Time/Discrete-Time ∑ Δ Modulators for Broadband Wireless Telecom Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This work analyzes the use of hybrid continuous-time/discrete-time ∑ Δ modulators for the implementation of analog-to-digital converters intended for wideband mobile applications. Two alternative multirate cascade ∑ Δ architectures are discussed and analyzed, taking into account the impact of main circuit-level error mechanisms, namely: mismatch, finite dc gain and gain-bandwidth product. Both multirate ∑ Δ modulators are compared with conventional single-rate continuous-time cascade ∑ Δ modulators in terms of their sensitivity to non-ideal effects, considering different target specifications. Theoretical predictions match simulation results, showing that the lowest performance degradation is obtained by a new kind of multi-rate hybrid ∑ Δ modulators, in which the continuous-time circuits operate at a higher rate than the discrete-time parts of the modulator.
978-3-642-28255-3_53_Chapter.pdf (4 Ko) Télécharger le fichier
hal-01365763 , version 1 (13-09-2016)
Paternité
J. Gerardo García-Sánchez, José de La Rosa. Efficient Hybrid Continuous-Time/Discrete-Time ∑ Δ Modulators for Broadband Wireless Telecom Systems. 3rd Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Feb 2012, Costa de Caparica, Portugal. pp.485-492, ⟨10.1007/978-3-642-28255-3_53⟩. ⟨hal-01365763⟩
31 Consultations
98 Téléchargements
