Dynamic Behavior of Resistive Random Access Memories (RRAMS) Based on Plastic Semiconductor - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Paulo F. Rocha
  • Fonction : Auteur
  • PersonId : 988886
Asal Kiazadeh
  • Fonction : Auteur
  • PersonId : 988887
Qian Chen
  • Fonction : Auteur
  • PersonId : 988888
Henrique L. Gomes
  • Fonction : Auteur
  • PersonId : 988889
Resistive Random Access Memories based on metal-oxide polymer diodes are characterized. The dynamic behavior is studied by recording current-voltage characteristics with varying voltage ramp speed. It is demonstrated that these organic memory devices have an internal capacitive double-layer structure, which inhibits the switching at high ramp rates (1000 V/s). This behavior is modeled and explained in terms of an equivalent circuit.
978-3-642-28255-3_59_Chapter.pdf (4 Ko) Télécharger le fichier
hal-01365773 , version 1 (13-09-2016)
Paternité
Paulo F. Rocha, Asal Kiazadeh, Qian Chen, Henrique L. Gomes. Dynamic Behavior of Resistive Random Access Memories (RRAMS) Based on Plastic Semiconductor. 3rd Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Feb 2012, Costa de Caparica, Portugal. pp.535-540, ⟨10.1007/978-3-642-28255-3_59⟩. ⟨hal-01365773⟩
69 Consultations
71 Téléchargements
