New interface
Other publications
Systematic Derivation of Bounds and Glue Constraints for Time-Series Constraints
Abstract : Integer time series are often subject to constraints on the aggregation of the integer features of all occurrences of some pattern within the series. For example, the number of inflexions may be constrained, or the sum of the peak maxima, or the minimum of the peak widths. It is currently unknown how to maintain domain consistency efficiently on such constraints. We propose parametric ways of systematically deriving glue constraints, which are a particular kind of implied constraints, as well as aggregation bounds that can be added to the decomposition of time-series constraints [5]. We evaluate the beneficial propagation impact of the derived implied constraints and bounds, both alone and together.
Complete list of metadata
Cited literature [15 references]  Display  Hide  Download
https://hal.inria.fr/hal-01370317
Contributor : Contraintes Lina Connect in order to contact the contributor
Submitted on : Tuesday, November 29, 2016 - 10:31:47 AM
Last modification on : Thursday, October 27, 2022 - 1:45:02 PM
Long-term archiving on: : Tuesday, March 21, 2017 - 10:56:56 AM
Identifiers
Citation
Ekaterina Arafailova, Nicolas Beldiceanu, Mats Carlsson, Pierre Flener, María Andreína Francisco Rodríguez, et al.. Systematic Derivation of Bounds and Glue Constraints for Time-Series Constraints. 2016, ⟨10.1007/978-3-319-44953-1_2⟩. ⟨hal-01370317⟩
Share
Metrics
Record views
544
Files downloads
336
