Efficient Identity-Based Signature from Lattices - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Identity-based signature is an important technique for light-weight authentication. Recently, many efforts have been made to construct identity-based signatures over lattice assumptions since they would remain secure in future quantum age. In this paper we present a new identity-based signature scheme from lattice problems. This scheme is more efficient than other lattice-based identity-based signature schemes in terms of both computation and communication complexities. We prove its security in the random oracle model under short integer solution assumption that is as hard as approximating several worst-case lattice problems.
978-3-642-55415-5_26_Chapter.pdf (4 Ko) Télécharger le fichier
hal-01370379 , version 1 (22-09-2016)
Paternité
Miaomiao Tian, Liusheng Huang. Efficient Identity-Based Signature from Lattices. 29th IFIP International Information Security Conference (SEC), Jun 2014, Marrakech, Morocco. pp.321-329, ⟨10.1007/978-3-642-55415-5_26⟩. ⟨hal-01370379⟩
97 Consultations
569 Téléchargements
