Authorship Attribution for Forensic Investigation with Thousands of Authors - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Min Yang
  • Fonction : Auteur
  • PersonId : 989409
Kam-Pui Chow
  • Fonction : Auteur
  • PersonId : 989410
With the popularity of computer and Internet, a growing number of criminals have been using the Internet to distribute a wide range of illegal materials and false information globally in an anonymous manner, making criminal identity tracing difficult in the cybercrime investigation process. Consequently, automatic authorship attribution of online messages becomes increasingly crucial for forensic investigation. Although researchers have got many achievements, the accuracies of authorship attribution with tens or thousands of candidate are still relatively poor which is generally among 20%~40%, and cannot be used as evidence in forensic investigation. Instead of asserting that a given text was written by a given user, this paper proposes a novel authorship attribution model combining both profile-based and instance-based approaches to reduce the size of the candidate authors to a small number and narrow the scope of investigation with a high level of accuracy. To evaluate the effectiveness of our model, we conduct extensive experiments on a blog corpus with thousands of candidate authors. The experimental results show that our algorithm can successfully output a small number of candidate authors with high accuracy.
978-3-642-55415-5_28_Chapter.pdf (4 Ko) Télécharger le fichier
hal-01370381 , version 1 (22-09-2016)
Paternité
Min Yang, Kam-Pui Chow. Authorship Attribution for Forensic Investigation with Thousands of Authors. 29th IFIP International Information Security Conference (SEC), Jun 2014, Marrakech, Morocco. pp.339-350, ⟨10.1007/978-3-642-55415-5_28⟩. ⟨hal-01370381⟩
180 Consultations
390 Téléchargements
