Stability and Robustness of Homogeneous Differential Inclusions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The known results on asymptotic stability of homogeneous differential inclusions with negative homogeneity degrees and their accuracy in the presence of noises and delays are extended to arbitrary homogeneity degrees. Discretization issues are considered, which include explicit and implicit Euler integration schemes. Computer simulation illustrates the theoretical results.
CDC16_1886_Arie.pdf (362.03 Ko) Télécharger le fichier
hal-01371280 , version 1 (25-09-2016)
  • HAL Id : hal-01371280 , version 1
Arie Levant, Denis Efimov, Andrey Polyakov, Wilfrid Perruquetti. Stability and Robustness of Homogeneous Differential Inclusions. Proc. 55th IEEE Conference on Decision and Control (CDC), Dec 2016, Las Vegas, United States. ⟨hal-01371280⟩
267 Consultations
301 Téléchargements
