Thermodynamic properties of ring polyelectrolytes in thebinding mean spherical approximation. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Molecular Liquids Année : 2016
A simple model for charged ring polyelectrolyte is proposed, to describe their thermodynamic properties. Starting from an analytical expressions previously obtained for charged chains within the binding mean spherical approximation, we present a method to determine suitable modifications in order to describe charged rings. It is shown that the electrostatic excess thermodynamic properties can still be computed from relatively simple formulas which involve a screening parameter Γ B .
Bernard_Thermodynamic.pdf (232.97 Ko) Télécharger le fichier
hal-01373753 , version 1 (29-09-2016)
Olivier Bernard, J.-P. Simonin. Thermodynamic properties of ring polyelectrolytes in thebinding mean spherical approximation.. Journal of Molecular Liquids, 2016, ⟨10.1016/j.molliq.2016.09.044⟩. ⟨hal-01373753⟩
205 Consultations
102 Téléchargements
