On locally irregular decompositions and the 1-2 Conjecture in digraphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2018
The 1-2 Conjecture raised by Przybylo and Wozniak in 2010 asserts that every undirected graph admits a 2-total-weighting such that the sums of weights "incident" to the vertices yield a proper vertex-colouring. Following several recent works bringing related problems and notions (such as the well-known 1-2-3 Conjecture, and the notion of locally irregular decompositions) to digraphs, we here introduce and study several variants of the 1-2 Conjecture for digraphs. For every such variant, we raise conjectures concerning the number of weights necessary to obtain a desired total-weighting in any digraph. We verify some of these conjectures, while we obtain close results towards the ones that are still open.
12oriented-110918.pdf (282.03 Ko) Télécharger le fichier
hal-01374427 , version 1 (30-09-2016)
hal-01374427 , version 2 (30-04-2018)
hal-01374427 , version 3 (23-08-2018)
hal-01374427 , version 4 (11-09-2018)
hal-01374427 , version 5 (29-09-2018)
  • HAL Id : hal-01374427 , version 4
Olivier Baudon, Julien Bensmail, Jakub Przybyło, Mariusz Woźniak. On locally irregular decompositions and the 1-2 Conjecture in digraphs. Discrete Mathematics and Theoretical Computer Science, In press. ⟨hal-01374427v4⟩
604 Consultations
860 Téléchargements
