A discrete approach for decomposing noisy digital contours into arcs and segments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In the paper, we present a method for decomposing a discrete noisy curve into arcs and segments which are the frequent primitives in digital images. This method is based on two tools: dominant point detection using adaptive tangential cover and tangent space representation of the polygon issued from detected dominant points. The experiments demonstrate the robustness of the method w.r.t. noise.
paperCR_W06-15.pdf (6.69 Mo) Télécharger le fichier
hal-01375089 , version 1 (03-10-2016)
Phuc Ngo, Hayat Nasser, Isabelle Debled-Rennesson. A discrete approach for decomposing noisy digital contours into arcs and segments. ACCV Workshop 2016, Nov 2016, Taipei, Taiwan. ⟨10.1007/978-3-319-54427-4_36⟩. ⟨hal-01375089⟩
173 Consultations
204 Téléchargements
