New interface
Journal articles
Discrete $p$-robust H(div)-liftings and a posteriori estimates for elliptic problems with $H^{-1}$ source terms
Abstract : We establish the existence of liftings into discrete subspaces of H(div) of piecewise polynomial data on locally refined simplicial partitions of polygonal/polyhedral domains. Our liftings are robust with respect to the polynomial degree. This result has important applications in the a posteriori error analysis of parabolic problems, where it permits the removal of so-called transition conditions that link two consecutive meshes. It can also be used in a the posteriori error analysis of elliptic problems, where it allows the treatment of meshes with arbitrary numbers of hanging nodes between elements. We present a constructive proof based on the a posteriori error analysis of an auxiliary elliptic problem with $H^{−1}$ source terms, thereby yielding results of independent interest. In particular, for such problems, we obtain guaranteed upper bounds on the error along with polynomial-degree robust local efficiency of the estimators.
Document type :
Journal articles
Complete list of metadata
Cited literature [16 references]  Display  Hide  Download
https://hal.inria.fr/hal-01377007
Contributor : Iain Smears Connect in order to contact the contributor
Submitted on : Thursday, October 6, 2016 - 1:32:24 PM
Last modification on : Monday, July 25, 2022 - 3:44:08 AM
Long-term archiving on: : Saturday, January 7, 2017 - 12:44:04 PM
File
robust_liftings.pdf
Identifiers
Citation
Alexandre Ern, Iain Smears, Martin Vohralík. Discrete $p$-robust H(div)-liftings and a posteriori estimates for elliptic problems with $H^{-1}$ source terms. Calcolo, 2017, 54 (3), pp.1009-1025. ⟨10.1007/s10092-017-0217-4⟩. ⟨hal-01377007⟩
Share
Metrics
Record views
261
Files downloads
146
