Different Approaches of the PLM Maturity Concept and Their Use Domains – Analysis of the State of the Art - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Product lifecycle management (PLM) implementation and adoption involves extensive changes in both intra- and inter-organizational practices. Various maturity approaches, for instance based on CMM (Capability maturity modeling) principles, can be used to make the implementation of PLM a better approachable and a more carefully planned and coordinated process. However, there are a number of different types of current approaches which can be thought to fall under the concept of PLM maturity. The aim of this paper is to investigate, analyze and categorize the various existing PLM maturity approaches to get an organized picture of the models and their background presumptions, as well as their potential use domains, and to facilitate their proper use to better implement PLM in different industry contexts.
421082_1_En_9_Chapter.pdf (176.13 Ko) Télécharger le fichier
hal-01377431 , version 1 (07-10-2016)
Paternité
Hannu Kärkkäinen, Anneli Silventoinen. Different Approaches of the PLM Maturity Concept and Their Use Domains – Analysis of the State of the Art. 12th IFIP International Conference on Product Lifecycle Management (PLM), Oct 2015, Doha, Qatar. pp.89-102, ⟨10.1007/978-3-319-33111-9_9⟩. ⟨hal-01377431⟩
104 Consultations
271 Téléchargements
