Knowledge Sharing Using Ontology Graph-Based: Application in PLM and Bio-Imaging Contexts - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Cong Cuong Pham
  • Fonction : Auteur
  • PersonId : 990043
Alexandre Durupt
Benoit Eynard
Data resources in PLM (Product Lifecycle Management) systems are becoming more and more huge and complex. The heterogeneity of data type and the dependencies among technical information make difficult for users in database exploitation: to query and to share the data. In this paper, we present an ontology-based approach as a promising solution to overcome this issue. An ontology graph-based query interface has been developed with the aim to enhance the knowledge sharing among different types of users (non-technical or coming from diverse expert domains) and then to facilitate the database exploitation. An example in Bio-Imaging domain will be presented as an application field.
421082_1_En_22_Chapter.pdf (879.85 Ko) Télécharger le fichier
hal-01377447 , version 1 (07-10-2016)
Paternité
Cong Cuong Pham, Alexandre Durupt, Nada Matta, Benoit Eynard. Knowledge Sharing Using Ontology Graph-Based: Application in PLM and Bio-Imaging Contexts. 12th IFIP International Conference on Product Lifecycle Management (PLM), Oct 2015, Doha, Qatar. pp.238-247, ⟨10.1007/978-3-319-33111-9_22⟩. ⟨hal-01377447⟩
264 Consultations
223 Téléchargements
