Manufacturability Assessment in the Conceptual Design of Aircraft Engines – Building Knowledge and Balancing Trade-Offs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Roland Stolt
  • Fonction : Auteur
  • PersonId : 990075
Samuel André
  • Fonction : Auteur
  • PersonId : 990076
Fredrik Elgh
  • Fonction : Auteur
  • PersonId : 990077
Petter Andersson
  • Fonction : Auteur
  • PersonId : 990078
This paper addresses the automated assessment of manufacturability of air-craft engine components in the early stages of design, focused on the welding process. It is a novel part of a multi-objective decision support tool for design evaluation, currently running at a manufacturer of jet engine components. The paper briefly describes the tool and how it impacts the product development process. Further, the paper presents an integrated method for manufacturability assessment by finding welding processes that complies with all geometrical and other constraints found in the CAD-models of the conceptual engine. Here, preferences made by manufacturing engineers serves as a base for a manufacturability index so that different parameter settings in the CAD-models can be compared to find the best parameter settings, considering the trade-off with other performance criteria’s of the engine.
421082_1_En_38_Chapter.pdf (177.83 Ko) Télécharger le fichier
hal-01377467 , version 1 (07-10-2016)
Paternité
Roland Stolt, Samuel André, Fredrik Elgh, Petter Andersson. Manufacturability Assessment in the Conceptual Design of Aircraft Engines – Building Knowledge and Balancing Trade-Offs. 12th IFIP International Conference on Product Lifecycle Management (PLM), Oct 2015, Doha, Qatar. pp.407-417, ⟨10.1007/978-3-319-33111-9_38⟩. ⟨hal-01377467⟩
103 Consultations
103 Téléchargements
