Virtual Validation of Automotive Measurement Services Based on JT (ISO 14306:2012) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper a concept for the virtual validation of automotive measurement services based on JT (ISO 14306:2012) is introduced. Each physical measuring component has a digital representation, represented by a 3D JT model. These models contain all necessary information of the measurement process and are the basis for the application of physical sensors. The developed concept enables the consistent usage of JT models and the suitable integration of virtual engineering methods into measuring services, resulting in improved efficiency and interoperability. For the implementation, instead of a CAD system, the viewing software Teamcenter Lifecycle Visualization Mockup is used. This leads to cost savings by the reduction of license fees. The concept is validated based on two measuring projects, containing separate component models and a complete vehicle model.
421082_1_En_46_Chapter.pdf (551.65 Ko) Télécharger le fichier
Format : Figure, Image
hal-01377477 , version 1 (07-10-2016)
Paternité
Andreas Faath, Alexander Christ, Reiner Anderl, Frank Braunroth. Virtual Validation of Automotive Measurement Services Based on JT (ISO 14306:2012). 12th IFIP International Conference on Product Lifecycle Management (PLM), Oct 2015, Doha, Qatar. pp.505-515, ⟨10.1007/978-3-319-33111-9_46⟩. ⟨hal-01377477⟩
105 Consultations
111 Téléchargements
