Master Data Management in PLM for the Enterprise Scope - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Sehyun Myung
  • Fonction : Auteur
  • PersonId : 990146
Establish and management of ‘Master Data’ is a prerequisite in the PLM system deployment. If the PLM project goes without company-wide ‘Master Data’, it is need to go back to the first step of the project and make these ‘Master Data’. In this paper, the definition of PLM, the process of the PLM system implementation, how to make a classification of ‘Master Data’ required for the PLM system deployment will be described.
421082_1_En_70_Chapter.pdf (723.89 Ko) Télécharger le fichier
hal-01377506 , version 1 (07-10-2016)
Paternité
Sehyun Myung. Master Data Management in PLM for the Enterprise Scope. 12th IFIP International Conference on Product Lifecycle Management (PLM), Oct 2015, Doha, Qatar. pp.771-779, ⟨10.1007/978-3-319-33111-9_70⟩. ⟨hal-01377506⟩
192 Consultations
460 Téléchargements
