A Scaling Analysis of a Star Network with Logarithmic Weights - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Stochastic Processes and their Applications Année : 2019
The paper investigates the properties of a class of resource allocation algorithms for communication networks: if a node of this network has $L$ requests to transmit and is idle, it tries to access the channel at a rate proportional to $\log(1{+}L)$. A stochastic model of such an algorithm is investigated in the case of the star network, in which $J$ nodes can transmit simultaneously, but interfere with a central node $0$ in such a way that node $0$ cannot transmit while one of the other nodes does. One studies the impact of the log policy on these $J{+}1$ interacting communication nodes. A fluid scaling analysis of the network is derived with the scaling parameter $N$ being the norm of the initial state. It is shown that the asymptotic fluid behavior of the system is a consequence of the evolution of the state of the network on a specific time scale $(N^t\!\!, t{\in}(0,1))$. The main result is that, on this time scale and under appropriate conditions, the state of a node with index $j{\geq}1$ is of the order of $N^{a_j(t)}$\!\!, with $0{\leq}a_j(t){<}1$, where $t{\mapsto}a_j(t)$ is a piecewise linear function. Convergence results on the fluid time scale and a stability property are derived as a consequence of this study.
hal-01377703 , version 1 (07-10-2016)
hal-01377703 , version 2 (27-04-2019)
Philippe Robert, Amandine Veber. A Scaling Analysis of a Star Network with Logarithmic Weights. Stochastic Processes and their Applications, 2019, 129 (5), pp.31. ⟨10.1016/j.spa.2018.06.002⟩. ⟨hal-01377703v1⟩
368 Consultations
97 Téléchargements
