A Local Velocity Grid Approach for BGK Equation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Communications in Computational Physics Année : 2014
The solution of complex rarefied flows with the BGK equation and the Discrete Velocity Method (DVM) requires a large number of velocity grid points leading to significant computational costs. We propose an adaptive velocity grid approach exploiting the fact that locally in space, the distribution function is supported only by a subset of the global velocity grid. The velocity grid is adapted thanks to criteria based on local temperature, velocity and on the enforcement of mass conservation. Simulations in 1D and 2D are presented for different Knudsen numbers and compared to a global velocity grid BGK solution, showing the computational gain of the proposed approach.
local_grids_final.pdf (202.99 Ko) Télécharger le fichier
hal-01377856 , version 1 (07-10-2016)
Florian Bernard, Angelo Iollo, Gabriella Puppo. A Local Velocity Grid Approach for BGK Equation. Communications in Computational Physics, 2014, 16, pp.956 - 982. ⟨10.4208/cicp.291013.240314a⟩. ⟨hal-01377856⟩
189 Consultations
181 Téléchargements
