New interface
Conference papers
Shock capturing computations with stabilized Powell-Sabin elements
Abstract : In the last recent years, thanks to the increasing power of the computational machines , the interest in more and more accurate numerical schemes is growing. Methods based on high-order approximations are nowadays the common trend in the computational research community, in particular for CFD applications. This work is focused on Powell-Sabin (PS) finite elements, a finite element method (FEM) based on PS splines. PS splines are piecewise quadratic polynomials with a global C1 continuity , defined on conforming triangulations. Despite its attractive characteristics, so far this scheme hasn't had the attention it deserves. PS splines are adapted to unstructured meshes and, contrary to classical tensor product B-splines, they are particularly suited for local refinement , a crucial aspect in the analysis of highly convective and anisotropic equations. The additional global smoothness of the C1 space has a beneficial stabilization effect in the treatment of advection-dominated equations and leads to a better capturing of thin layers. Finally, unlike most of other typology of high-order finite elements, the numerical unknowns in PS elements are located in the vertices of the triangulation, leading to an easy treatment of the parallel aspects. Some geometrical issues related to PS elements are discussed here, in particular, the generation of the control triangles and the imposition of the boundary conditions. The PS FEM method is used to solve the compressible Euler equation in supersonic regime. A classical shock-capturing technique is used to reduce the oscillation around the discontinuity, while a variational multiscale formulation is used to introduce numerical diffusion in the streamwise direction. Some typical numerical examples are used to evaluate the performance of the PS discretization.
Complete list of metadata
Cited literature [16 references]  Display  Hide  Download
https://hal.inria.fr/hal-01377909
Contributor : Herve Guillard Connect in order to contact the contributor
Submitted on : Friday, October 7, 2016 - 8:02:06 PM
Last modification on : Thursday, August 4, 2022 - 4:58:36 PM
Long-term archiving on: : Friday, February 3, 2017 - 11:50:46 PM
File
Eccomas2016.pdf
Identifiers
  • HAL Id : hal-01377909, version 1
Citation
Giorgio Giorgiani, Hervé Guillard, Boniface Nkonga. Shock capturing computations with stabilized Powell-Sabin elements. ECCOMAS Congress 2016 VII European Congress on Computational Methods in Applied Sciences and Engineering, Jun 2016, Crete, Greece. pp.16. ⟨hal-01377909⟩
Share
Metrics
Record views
578
Files downloads
195
