On Shapley value for measuring importance of dependent inputs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM/ASA Journal on Uncertainty Quantification Année : 2017
This paper makes the case for using Shapley value to quantify the importance of random input variables to a function. Alternatives based on the ANOVA decomposition can run into conceptual and computational problems when the input variables are dependent. Our main goal here is to show that Shapley value removes the conceptual problems. We do this with some simple examples where Shapley value leads to intuitively reasonable nearly closed form values.
VersionHalOwenPrieurMars2017.pdf (319.75 Ko) Télécharger le fichier
hal-01379188 , version 1 (11-10-2016)
hal-01379188 , version 2 (15-03-2017)
hal-01379188 , version 3 (21-03-2017)
Art B Owen, Clémentine Prieur. On Shapley value for measuring importance of dependent inputs. SIAM/ASA Journal on Uncertainty Quantification, 2017. ⟨hal-01379188v2⟩
652 Consultations
725 Téléchargements
