Lattice Attacks against Elliptic-Curve Signatures with Blinded Scalar Multiplication - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Elliptic curve cryptography is today the prevailing approach to get efficient public-key cryptosystems and digital signatures. Most of elliptic curve signature schemes use a \emph{nonce} in the computation of each signature and the knowledge of this nonce is sufficient to fully recover the secret key of the scheme. Even a few bits of the nonce over several signatures allow a complete break of the scheme by lattice-based attacks. Several works have investigated how to efficiently apply such attacks when partial information on the nonce can be recovered through side-channel attacks. However, these attacks usually target unprotected implementation and/or make ideal assumptions on the recovered information, and it is not clear how they would perform in a scenario where common countermeasures are included and where only noisy information leaks via side channels. In this paper, we close this gap by applying such attack techniques against elliptic-curve signature implementations based on a blinded scalar multiplication. Specifically, we extend the famous Howgrave-Graham and Smart lattice attack when the nonces are blinded by the addition of a random multiple of the elliptic-curve group order or by a random Euclidean splitting. We then assume that noisy information on the blinded nonce can be obtained through a template attack targeting the underlying scalar multiplication and we show how to characterize the obtained likelihood scores under a realistic leakage assumption. To deal with this scenario, we introduce a filtering method which given a set of signatures and associated likelihood scores maximizes the success probability of the lattice attack. Our approach is backed up with attack simulation results for several signal-to-noise ratio of the exploited leakage.
sac16.pdf (396.82 Ko) Télécharger le fichier
hal-01379249 , version 1 (13-05-2020)
  • HAL Id : hal-01379249 , version 1
Dahmun Goudarzi, Matthieu Rivain, Damien Vergnaud. Lattice Attacks against Elliptic-Curve Signatures with Blinded Scalar Multiplication. Selected Areas in Cryptography - SAC 2016, Aug 2016, St. John’s, Canada. ⟨hal-01379249⟩
365 Consultations
1004 Téléchargements
