New Scan-Based Attack Using Only the Test Mode and an Input Corruption Countermeasure - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Sk Subidh Ali
  • Fonction : Auteur
  • PersonId : 990366
Ozgur Sinanoglu
  • Fonction : Auteur
  • PersonId : 990368
Ramesh Karri
  • Fonction : Auteur
  • PersonId : 990369
Scan-based design-for-testability, which improves access and thus the test quality, is highly vulnerable to scan attack. While in-field test is enabled through the scan design to provide debug capabilities, an attacker can leverage the test mode to leak the secret key of the chip. The scan attack can be thwarted by a simple defense that resets the data upon a switch from the normal mode to the test mode. We proposed a new class of scan attack in [15] using only the test mode of a chip, circumventing this defense. In this book chapter we extend our earlier work by introducing case studies to explain this new attack in greater detail. Furthermore, we study the effectiveness of existing countermeasures to thwart the attack and propose a new input corruption countermeasure that requires a smaller area overhead compared to the existing countermeasures.
367527_1_En_3_Chapter.pdf (626.46 Ko) Télécharger le fichier
hal-01380298 , version 1 (12-10-2016)
Paternité
Sk Subidh Ali, Samah Mohamed Saeed, Ozgur Sinanoglu, Ramesh Karri. New Scan-Based Attack Using Only the Test Mode and an Input Corruption Countermeasure. 21th IFIP/IEEE International Conference on Very Large Scale Integration - System on a Chip (VLSI-SoC), Oct 2013, Istanbul, Turkey. pp.48-68, ⟨10.1007/978-3-319-23799-2_3⟩. ⟨hal-01380298⟩
204 Consultations
231 Téléchargements
