A peak detection method for identifying phase in physiological signals - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Biomedical Signal Processing and Control Année : 2017
Introduction To understand the integrated behavior of biological systems, the interactions between their constituent parts are often studied. For example, the interaction between blood pressure and heart rate reveals information about the cardiac baroreflex. For the purpose of characterizing relationships between physiological signals, it is useful to identify phase either as a primary outcome or as an intermediate step to obtain other relevant secondary indices. Existing methods for phase estimation in physiological signals often suffer from a lack of thorough description and standardization, which renders reproducibility and interpretation difficult. A relatively simpler peak detection algorithm was compared to the gold standards of wavelet and Hilbert transforms for its ability to obtain phase. Methods The accuracy and computation time of the peak detection algorithm was compared to the gold standard methods in silico by applying all three to data of known phase, and signal-to-noise ratios from −20 to 5 dB. We then compared the performance of the peak detection method to the Hilbert and wavelet methods by applying each to four different types of in vivo data. Results The peak detection technique is less susceptible to noise and over 10 times faster, computationally, than the wavelet technique. Application to in vivo physiological data shows that equivalent results are obtained from each technique. Conclusions The peak detection method can be used to obtain phase in physiological signals, provide a clearer and more direct interpretation, and be more easily reproducible. Because of its design features, peak detection could also be used to identify individual oscillations in relevant signals, as well as to obtain amplitudes and direct time delays.
Phase_Detectors_PeakDet_Twist.pdf (1.22 Mo) Télécharger le fichier
hal-01380875 , version 1 (13-10-2016)
Copyright (Tous droits réservés)
Nicholas Mitrou, Alexandre Laurin, Taylor Dick, Jessica Inskip. A peak detection method for identifying phase in physiological signals. Biomedical Signal Processing and Control, 2017, 31, pp.452 - 462. ⟨10.1016/j.bspc.2016.07.001⟩. ⟨hal-01380875⟩
410 Consultations
761 Téléchargements
