VR-based Operating Modes and Metaphors for Collaborative Ergonomic Design of Industrial Workstations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal on Multimodal User Interfaces Année : 2016
The aim of this paper is to evaluate two new operating design modes and their collaborative metaphors enabling two actors, a design engineer and an end-user, to work jointly in a collabora-tive virtual environment for workstation design. The two operating design modes that correspond to two different design paradigms include : direct design mode (the design engineer manipulates objects while the end-user specifies their activity constraints) and supervised design mode (the end-user manipulates objects while the design engineer specifies their process constraints). The corresponding collaborative metaphors enable the two actors to manipulate objects while one (the design engineer) can express process constraints and the other (the end-user) can express activity constraints. The usability evaluation of the modes and metaphors consisted in placing a workstation design element on a digital workstation mock-up where a trade-off was to be found between process constraints and activity constraints. The results show that if we consider the completion time as the most important criterion to achieve, the direct design mode must be favoured. Otherwise , if the activity constraints are predominant, the supervised design mode must be favoured. In any case, the addition of an ergonomist's point of view is supported and warranted in order to enhance the effectiveness of the system.
JMUI_author.pdf (3.37 Mo) Télécharger le fichier
hal-01381243 , version 1 (14-10-2016)
Huyen Nguyen, Charles Pontonnier, Simon Hilt, Thierry Duval, Georges Dumont. VR-based Operating Modes and Metaphors for Collaborative Ergonomic Design of Industrial Workstations. Journal on Multimodal User Interfaces, 2016, 11 (1), pp.97-111. ⟨10.1007/s12193-016-0231-x⟩. ⟨hal-01381243⟩
934 Consultations
435 Téléchargements
