Bin packing with colocations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2016
Motivated by an assignment problem arising in MapReduce computations , we investigate a generalization of the Bin Packing problem which we call Bin Packing with Colocations Problem. Given a set V of items with positive integer weights, an underlying graph G = (V, E), and an integer q, the goal is to pack the items into a minimum number of bins so that (i) the total weight of the items packed in every bin is at most q, and (ii) for each edge (i, j) ∈ E there is at least one bin containing both items i and j. We first show that when the underlying graph is unweighted (i.e., all the items have equal weights), the problem is equivalent to the q-clique problem, and when furthermore the underlying graph is a clique, optimal solutions are obtained from covering designs. We prove that the problem becomes NP-hard even for weighted paths and un-weighted trees and we propose approximation algorithms for particular families of graphs, including: a (3 + √ 5)-approximate algorithm for weighted complete graphs (improving a previous 8-approximation), a 2-approximate algorithm for weighted paths, a 5-approximate algorithm for weighted trees, and an (1+)-approximate algorithm for unweighted trees. For general weighted graphs, we propose a 3 + 2mad(G)/2-approximate algorithm, where mad(G) is the maximum average degree of G. Finally, we show how to convert any ρ-approximation algorithm for the Bin Packing (resp. the Densest q-Subgraph problem) into an approximation algorithm for the problem on weighted (resp. unweighted) general graphs.
bin-packing-rr.pdf (247.08 Ko) Télécharger le fichier
hal-01381333 , version 1 (14-10-2016)
hal-01381333 , version 2 (17-03-2018)
  • HAL Id : hal-01381333 , version 1
Jean-Claude Bermond, Nathann Cohen, David Coudert, Dimitrios Letsios, Ioannis Milis, et al.. Bin packing with colocations. [Research Report] Inria; I3S. 2016. ⟨hal-01381333v1⟩
945 Consultations
995 Téléchargements
