Anisotropic Boltzmann-Gibbs dynamics of strongly magnetized Vlasov-Fokker-Planck equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2016
We consider various sets of Vlasov-Fokker-Planck equations modeling the dynamics of charged particles in a plasma under the effect of a strong magnetic field. For each of them in a regime where the strength of the magnetic field is effectively stronger than that of collisions we first formally derive asymptotically reduced models. In this regime, strong anisotropic phenomena occur; while equilibrium along magnetic field lines is asymptotically reached our asymptotic models capture a non trivial dynamics in the perpendicular directions. We do check that in any case the obtained asymptotic model defines a well-posed dynamical system and when self consistent electric fields are neglected we provide a rigorous mathematical justification of the formally derived systems. In this last step we provide a complete control on solutions by developing anisotropic hypocoercive estimates.
preprint.pdf (647.32 Ko) Télécharger le fichier
hal-01382854 , version 1 (17-10-2016)
hal-01382854 , version 2 (13-12-2018)
  • HAL Id : hal-01382854 , version 1
Maxime Herda, Luis Miguel Miguel Rodrigues. Anisotropic Boltzmann-Gibbs dynamics of strongly magnetized Vlasov-Fokker-Planck equations. 2016. ⟨hal-01382854v1⟩
950 Consultations
168 Téléchargements
