Rule-Based Multi-criteria Framework for SaaS Application Architecture Selection - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Falak Nawaz
  • Fonction : Auteur
  • PersonId : 990935
Ahmad Mohsin
  • Fonction : Auteur
  • PersonId : 990936
Syda Fatima
  • Fonction : Auteur
  • PersonId : 990937
Software-as-a-service (SaaS) is a very successful model for providing cloud-based services over the internet. However, due to the dynamic nature of SaaS services, it becomes very challenging to ensure provision of scalability, applying frequent maintenance and functionality updates to SaaS Services. SOAP and REST are the two mostly used software architectural styles for accessing and consuming SaaS services in cloud environment and each have its distinct advantages. Therefore, to address above mentioned challenges, it is critical to choose the suitable architectural style because the success of a SaaS is strongly coupled with its architecture style. Choosing the right software architecture for a system is a multi-criteria decision making problem and it takes into consideration the architectural style characteristics, non-functional requirements and working domain requirements. In this paper, we propose a rule-based multi-criteria decision support system (DSS) for a SaaS application architecture selection. Our proposed DSS uses weighted sum model (WSM) that take into account the architectural style characteristics, non-functional and domain specific requirements.
371690_1_En_12_Chapter.pdf (114.77 Ko) Télécharger le fichier
hal-01383961 , version 1 (19-10-2016)
Paternité
Falak Nawaz, Ahmad Mohsin, Syda Fatima, Naeem Khalid Janjua. Rule-Based Multi-criteria Framework for SaaS Application Architecture Selection. 4th IFIP International Conference on Artificial Intelligence in Theory and Practice (AI 2015), Oct 2015, Daejeon, South Korea. pp.129-138, ⟨10.1007/978-3-319-25261-2_12⟩. ⟨hal-01383961⟩
281 Consultations
262 Téléchargements
