New interface
Conference papers
Compressive K-means
Nicolas Keriven 1 Nicolas Tremblay 2 Yann Traonmilin 1 Rémi Gribonval 1
1 PANAMA - Parcimonie et Nouveaux Algorithmes pour le Signal et la Modélisation Audio
Inria Rennes – Bretagne Atlantique , IRISA-D5 - SIGNAUX ET IMAGES NUMÉRIQUES, ROBOTIQUE
Abstract : The Lloyd-Max algorithm is a classical approach to perform K-means clustering. Unfortunately, its cost becomes prohibitive as the training dataset grows large. We propose a compressive version of K-means (CKM), that estimates cluster centers from a sketch, i.e. from a drastically compressed representation of the training dataset. We demonstrate empirically that CKM performs similarly to Lloyd-Max, for a sketch size proportional to the number of cen-troids times the ambient dimension, and independent of the size of the original dataset. Given the sketch, the computational complexity of CKM is also independent of the size of the dataset. Unlike Lloyd-Max which requires several replicates, we further demonstrate that CKM is almost insensitive to initialization. For a large dataset of 10^7 data points, we show that CKM can run two orders of magnitude faster than five replicates of Lloyd-Max, with similar clustering performance on artificial data. Finally, CKM achieves lower classification errors on handwritten digits classification.
Complete list of metadata
https://hal.inria.fr/hal-01386077
Contributor : Nicolas Keriven Connect in order to contact the contributor
Submitted on : Friday, February 10, 2017 - 10:57:14 AM
Last modification on : Saturday, August 6, 2022 - 3:32:50 AM
paper.pdf
Identifiers
  • HAL Id : hal-01386077, version 4
  • ARXIV : 1610.08738
Citation
Nicolas Keriven, Nicolas Tremblay, Yann Traonmilin, Rémi Gribonval. Compressive K-means. ICASSP 2017 - IEEE International Conference on Acoustics, Speech and Signal Processing, Mar 2017, New Orleans, United States. ⟨hal-01386077v4⟩
Share
Metrics
Record views
962
Files downloads
695
